Author Topic: Building A Junkyard Dana 60 For A TJ,XJ,YJ,JK  (Read 4307 times)
0 Members and 4 Guests are viewing this topic.
wb joe
  • Founder/President - Member #101
« Reply #-1 on: May 02, 2013, 12:31:36 PM »
Got this from JP mag
When it comes to front axles, the Dana 60 is pretty much the gold standard. It enables you to confidently stay in the throttle longer, bounce harder, and lift later than if you have a pair of potential grenades under your rig. Of course, there are several companies willing to build you a complete Dana 60 that bolts under your Jeep, but if you’re on a beer budget, those champagne tastes are a little out of reach. Many of us have a hard enough time keeping credit card balances to a minimum without a money-Hoovering Jeep addiction.
For us, we started getting serious about upgrading when we noticed years of swinging 37s off a TJ Dana 30 front axle was gradually bending the housing into a quite visible U-shape (keep in mind we don’t make a habit of jumping it). Plus, we were getting tired of swapping parts on the trail and carting around spares of everything, including a spare ring-and-pinion during extended trips. We scored a highly coveted high-pinion Ford Dana 60 for $650 thanks to sharp-eyed friend and Feature Editor Verne Simons. It was complete and hiding in plain sight right on the local junkyard inventory portal car-part.com. We immediately called the junkyard and put down a deposit over the phone. A couple of days later the yard presented us with a pristine Dana 60 that they had even been kind enough to steam clean and paint! We loaded it up and peeled out before someone figured out they had sold us the axle at about 50 percent the going rate, and we didn’t have to spin a single wrench to get it.
Follow along as we highlight what it takes to build a junkyard Dana 60 front axle that’s ready to bolt into a TJ, XJ, MJ, or even a ZJ. We’ll show you what went well, what didn’t, and how we solved the problems we encountered. While it took quite a bit of elbow grease, we’re giggling like a little schoolgirl knowing that we now have a front axle we can hammer on without barfing parts all over the trail.
To Chop or Not To Chop, and How Much?
 We considered just running the axle full width, which would have saved time and money, but in the end decided to shorten it for a variety of reasons. First, full-width axles have advantages and disadvantages on the trail, and for most of the wheeling we do, narrower is a little better. Second, we wanted to get closer to the width of the rear axle than farther away; though we plan on upgrading the rear at some point, it might be a couple of years down the road. Third, though the vehicle is street legal it also spends its fair share of time being trailered to events, so we wanted to make it would fit without making a bunch of trailer modifications.
There are a lot of things to take into account when deciding on a final overall WMS-WMS (Wheel Mounting Surface) width like tire size, wheel offset, frame clearance, axle bracket location, and fender coverage. A factory TJ Dana 30 is about 60 3⁄4 inches wide. Our TJ had an old Warn hub conversion, which pushed the width another ¾-inch on each side. Still, the 37-inch tires rubbed the frame slightly, and we wanted room to run 40s someday. We ultimately decided that 65 inches would be ideal. The factory Ford WMS-WMS is 691⁄4 inches, which meant chopping 41⁄4 inches off of the passenger side of the axletube.
We were going to take a stab at shortening the housing ourselves, but we were pretty nervous about screwing it up and really didn’t have all the right tools to get the job done, namely a torch and the skills to use it without gouging up the tube and the inner C. We were about to go ahead and take the plunge anyway when a local wheeler turned us on to Arizona Differential, who quoted us an amazing $200 to shorten one side of our housing. Done deal. Now that we’ve seen it done, we’re confident we or anyone else with a fair amount of fabrication experience could do it, but at only $200, we’d still probably pay to have it done, mostly due to the time and hassle factor.
Read more: http://www.jpmagazine.com/techarticles/drivetrain/154_1209_building_a_junkyard_dana_60_for_a_tj/#ixzz2S9Zi42AN
bronco kev
Re: Building A Junkyard Dana 60 For A TJ,XJ,YJ,JK
« on: June 06, 2013, 05:53:32 PM »
you coulda used a pipe cutter to make a nice even cut.how thick is the tube?
chknkatsu
« Reply #1 on: June 19, 2013, 10:47:17 PM »
tubes on HD axles are usually 1/2" and the OD is about 3.125" - 3.25" i believe
locked, lifted, n' geared 2010 JK
foolswithtools.blogspot.com
raptor 2764
  • Guest
« Reply #2 on: August 04, 2013, 12:32:37 PM »
i have a dana 30 you guys can cut up .. come get it . still has gears in it . i also have both ,a band saw also a pipe cutter  a large one will cut up to 4 inch .also have a chop saw , with a new blade should do the job too
« Reply #3 on: August 04, 2013, 02:00:02 PM »
Yea chop saw with a carbide blade
But a bandsaw would work too
wb joe
« Reply #4 on: August 04, 2013, 02:32:17 PM »
there's nothing to chop this is just a info thread guy's
bronco kev
« Reply #5 on: August 26, 2013, 07:05:34 PM »
yeah, it gets outta hand.lol
