Paid member meet sunday march 6 2016 at jacksons in commack LI. all info in the event section .
Author Topic: ABS brakes  (Read 1237 times)
ABS brakes
« Reply #-1 on: September 06, 2013, 11:22:33 AM »
Ok, I'm havin trouble with my anti locks. Does anyone know witch plug it is to pull to turn it off on a spacific wheel like on my front drivers side only. I think I have a bad sensor and its making the breaks activate on that wheel. Got stuck in some deep mud last saterday and it might have done something to it. I'm hoping if I disconnect it it will stop until I get over to the dealer to fix it
NJJeeperNick
  • JEEP-its in my blood
    • MY OFFICIAL BUILD THREAD
Re: ABS brakes
« on: September 06, 2013, 12:00:10 PM »
Joe can correct me of needed, but you should be able to take out the relay from the fuse box under the hod.. you'll lose ABS until you fix the sensor. Its like 800-1000 to fix that. Sure lts the ABS and not traction controk
3" zone AAL,  IRO. LcA, IRO tracbar, ZJ tie rod, JKs quick discos, 235/70/16 destination ATs, FULLY swayless, Disc brakes all around, ruff stuff Dana 30 diff cover, and some other goodies
Re: ABS brakes
« Reply #1 on: September 06, 2013, 12:08:21 PM »
I'm pretty Shure. The abs light is on and I did a little research and its probably a bad sensor and I found out how to pull it and clean it sometimes it works. I did get into some deep thick mud
NJJeeperNick
Re: ABS brakes
« Reply #2 on: September 06, 2013, 12:39:15 PM »
OK the light is on. Pull the fuse for now from under the Hood and go somewhere you can.slam.on your brakes to.confirm reason I wanted someone else to confirm is because these new vehicles like to not work when things are pulled. Its a 30-40a relay.
