Author Topic: Wet carpet  (Read 2253 times)
Surffisher
  • 2014 JKU Sahara
Wet carpet
« Reply #-1 on: November 07, 2014, 07:52:00 AM »
I have a 2014 jku I have the slush mats and I just noticed that the Carpet under the mat in front passenger side is soaking wet. Any idea why? Please help!
Roy626
  • Forum Jr. Member
Re: Wet carpet
« on: November 07, 2014, 11:15:04 AM »
Not sure if it's the same on JK's but there should be a drain to allow A/C condensation to drain off. It usually gets clogged with leaves and dirt and the water flows into the PS floor. Check under your jeep PS firewall or might be accessible from under the hood. Although JK's don't leave much room under the hood. Hope this helps!
Roy
NJJeeperNick
  • JEEP-its in my blood
    • MY OFFICIAL BUILD THREAD
Re: Wet carpet
« Reply #1 on: November 08, 2014, 11:52:44 AM »
Also smell it too. It can be your evap leaking coolant into that area. Have you checked fluid levels.
3" zone AAL,  IRO. LcA, IRO tracbar, ZJ tie rod, JKs quick discos, 235/70/16 destination ATs, FULLY swayless, Disc brakes all around, ruff stuff Dana 30 diff cover, and some other goodies
Re: Wet carpet
« Reply #2 on: November 08, 2014, 02:56:42 PM »
It's probably the doors. Next time it rains watch the bottom corners
NJJeeperNick
Re: Wet carpet
« Reply #3 on: November 09, 2014, 08:18:47 PM »
It's funny you say this. Have a friend with a soft top jku and the rear passenger door would leak because the lining had moved from around the door. Dealership wanted $250 to fix so be called me and that's when we found that.
insanitize
  • NYCJC Member
  • Forum Jr. Member
Re: Wet carpet
« Reply #4 on: November 10, 2014, 10:12:59 AM »
Check the seals around the roof, they are known to leak.
2007 Modded and abused, the trashiest JK around
Surffisher
  • 2014 JKU Sahara
Re: Wet carpet
« Reply #5 on: November 14, 2014, 08:01:09 AM »
I have the freedom 3 piece top on, I took the panels off and put them back on, I figured maybe I didn't put them back on quite straight last time, I guess I will check again to see if that solves the issue the next time it rains.
Surffisher
  • 2014 JKU Sahara
Re: Wet carpet
« Reply #6 on: November 21, 2014, 07:57:14 AM »
We have had rain since this post from me and I have not had any issue as of today. Im still in the testing phase as when it did rain I was not driving. Tbc
Cybergrunt
  • Club Secretary - Member #107
Re: Wet carpet
« Reply #7 on: January 26, 2015, 06:06:53 AM »
How did you make out with the leak?
reoland
Re: Wet carpet
« Reply #8 on: April 06, 2018, 01:34:12 AM »
If you have soft doors, it can be the culprit.
