Author Topic: abs light came on!  (Read 1387 times)
Paulie P
  • Forum Jr. Member
  • A little at a time!
abs light came on!
« Reply #-1 on: June 28, 2012, 11:36:12 AM »
So my abs light came on today and i can't understand. why is it on? i checked for codes on obd2 port nothing there.
97TJsportBrightjadegreen
235/75 grabbers
wb joe
  • Founder/President - Member #101
Re: abs light came on!
« on: June 28, 2012, 05:16:03 PM »
your scanner need to have abs capability.dose it? prob just a speed sensor
Paulie P
  • Forum Jr. Member
« Reply #1 on: June 28, 2012, 06:31:10 PM »
I have no idea if that is the problem. I was think of disconnecting the battery hopefully it might work.
235/75 grabbers
Paulie P
  • Forum Jr. Member
« Reply #2 on: June 29, 2012, 09:52:18 AM »
This morning i went for a drive and the abs light was off. under a normal traffic stop i braked  on a dry road surface and the abs kicked in i was go 15mph and i was like "what the hell" then the dam abs light came back on again.
235/75 grabbers
BIG ROB
  • The Enforcer
  • john 8:7 lev.24:20 psalm23:4
« Reply #3 on: June 29, 2012, 10:03:25 AM »
Had same issue with my camaro. It was a loose wire  under my front passager side capliber
HEMI  !!!!!!
wb joe
« Reply #4 on: June 29, 2012, 10:39:56 AM »
I took out the abs out of my xj.or is should say took the fuses out for the abs motor and one for the light it is not good on the trail for me and with my 33's i cant lock them up any way and onec i put the D44 in the rear no more speed sensors.
Paulie P
  • Forum Jr. Member
« Reply #5 on: June 30, 2012, 11:04:57 AM »
found the problem the right rear sensor is bad. now i have to find one and replace it  ???
235/75 grabbers
Paulie P
  • Forum Jr. Member
« Reply #6 on: July 02, 2012, 09:53:00 PM »
Does anyone know where i can find an passenger/rear abs sensor alittle cheaper, i can only find it online for $119.
235/75 grabbers
